Do you mean
Newbie
0
Cannot connect my samsung smart tv
Hello,
we have a HH 2.0 and have recently bought a samsung smart tv.
I am trying to connect the tv to the hub use homeplug adapters.
When i try to setup the network on the tv it detects that the cable is plugged in but cannot access the network because of an IP or DHCP problem.
I have checked and DCHP is definitely enabled. But still cannot connect.
I have tried reseting the hub and manually entering IP details but to no avail.
I dont really want to have to pay £15 to speak to techdesk can anyone help??
Thanks.
0
Re: Cannot connect my samsung smart tv
This may help.
Samsung Smart TV
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
0
have you paired the powerline adapters?  only reason I ask as there was a previous similar post and that was the problem
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Newbie
0
ok erm im not really sure what that means i will try and see the other post
0
there are buttons on the power line adapters and you need to pair to each other very similar to pairing a bluetooth headset to a mobile phone.  in this case it usually is press one powerline button and then when light flashes presee the other and they then pair and can 'see' each other
