Do you mean
0
Fibre Optic cable in my area
Please BT, can I have fibre optic cables in my area. I currently measure my broadband speed in k's NOT mg's  I have a connection speed of 0.56 megs !!!  We have had a period recently of stolen telephone cables,I bet they have been replaced with copper cables. Why couldn't fibre optic cables been installed then ?  I am fed up of being oh so slow !!
0
Re: Fibre Optic cable in my area
[ Edited ]
you and thousands of others have the same wish - me included
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
0
Hi BT do not install fibre or copper that is done by OPENREACH Your recently replaced cables may have been replaced by either copper or fibre but until infinity is installed in your area you will not get fibre speeds
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
