Do you mean
Expert
0
Firmware Update Home Hub 3 B
A firmware update for the HH 3 B is being rolled out.
Has anyone installed this yet ?
Does anyone know what changes have been made ?
Current version is V100R001C01B036SP03_L_B .
What is the version of the update ?
Can we please have an update like this please:
http://community.bt.com/t5/BT-Infinity/Hub-3A-Upgrade-Info-Rollout-starting-7-November/td-p/689584
Expert
0
Re: Firmware Update Home Hub 3 B
An additional question.
The firmware gets dowloaded to your Hub automatically and then gets installed when the ACS sends a reboot command.
If you do the reboot manually does it install the new firmware ?
Expert
0
The answer to this appears to be that the ACS sends a command to install the firmware and then reboots the hub to use the new firmware. Therefore a manual reboot does not install the new firmware.
Expert
0
I have received another download of new firmware without the previous version being installed. Surely the moderators can give us an update on this ?
