Do you mean
0
HomeHub 4 USB Connection and Drives
Hi
Can anyone tell me what the maximum capacity for a usb hard drive connected to the homehub 4, as I have succeeded with my usb drives except my 1.5tb and 2.5tb drives it shows them listed but says the files are not in the correct format but they are in the same format as the other drives that do work.
any help much thanked for
0
Re: HomeHub 4 USB Connection and Drives
Can you say how you got usb to work. This poster is having problems.
http://community.bt.com/t5/Other-BB-Queries/USB-memory-stick-and-Home-Hub-3/td-p/882358
