Do you mean
Newbie
0
Accepted Solution
Increasing wireless range with Home Hub 3b
Hi,
I have just connected Home Hub 2 as slave to my Home Hub 3b as primary ... I was all excited because it seems to work .... to a point...  I have hit the known MAC routing "feature" of the HH3b (after reading the post  "Link BT Home Hub 3a and 3b together")  ie I can roam from primary to slave but not the other way round (unless I reset HH3).
My question is.... If I were to buy a wireless repeater, will I hit the same problem?
If yes, how can I increase my wireless range? Do I need to replace my Home Hub 3b? If so, any recommendations?
Can BT help? Is it worth calling them?
Many thanks,
0
Re: Increasing wireless range with Home Hub 3b
This is help pages done by Keith which will help
http://forumhelp.dyndns.info/index.html
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
CecileD wrote:
Hi,
Many thanks,
You will get that issue if you use the HH3B, as that is the way its designed.
A Universal Wireless Repeater overcomes the issue, by presenting all connections on the wireless interface.
There are a couple of options on this menu.
The Netgear one is supposed to be simpler, but quite a bit more expensive.
Wireless connection problems
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
Newbie
0
Thank you for your prompt responses. I think I will try the universal wireless repeater per Keith's suggestions.
