Do you mean
0
Interference when streaming music.
I've been getting interference when streaming music from We7, online radios etc. I use Windows XP and the problem is not from my equipment or any surrounding equipment.
I've contacted BT but they say it will cost me about £30 for them to do tests. Can anyone tell me what these tests are or what the problem might be?
Thank you
Sam
0
Re: Interference when streaming music.
What sort of interference? Is is a loud noise, crackling or hissing noise?
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
Guru
0
I take it you're connecting wirelessly?
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
0
The interference varies. Usually crackling with slight gaps in music. Recently there's been some slowing down of the music.
Sam
0
No, not connected wirelessly. I've had an expert come in and he confirms there is nothing wrong with any of my equipment nor is the interference caused by anything a neighbour might be doing,
Sam
0
If you are using wireless, then its probably wireless interference. Try changing the wireless channel that the home hub is set to.
You need a good stong wireless signal to stream music, and you can still get problems with wireless interference.
0
Are you on an ADSL connection, and which home hub version do you have?
0
No, as I said I'm not using wireless.
Sam
0
What about my last question?
0
ADSL connection; Home Hub 3.
Sam
