Do you mean
Newbie
0
Mcafee scans how to identify and remove trojans
[ Edited ]
I performed a scan using Mcafee scheduled scan and it located 1 trojan found. Where can i find details of this and whether it has been removed or what I should do to remove it ? Does Mcafee find viruses and ignore them and if not what does it do with them ?
0
Re: Mcafee scans how to identify and remove trojans
I can't answer your question on McAfee - I don't use it. I'm sure someone else who does will though.
Two other things I would do are:
(i) check if it is a false positive by submiting to virustotal
https://www.virustotal.com/
(ii) if it is real malware download and install malwarebytes antimalware free. Update it and run a quick scan to check for any remanants/effects that McAfee may not have dealt with.
http://www.malwarebytes.org/
0
Not sure if this might help with your inital question (as I say, I don't use McAfee, so I can't check).
http://bt.custhelp.com/ci/fattach/get/2294280/1329837794/redirect/1
