Do you mean
Newbie
0
Nintendo wii not connecting to bt infinity!
Just got upgrade to bt infinity and it doesnt work on my wii.  Have looked on here and stopped my hun3 from automatically changing channels. and even had a few fiddles with the ip address etc. cant get anything to work!!
0
Re: Nintendo wii not connecting to bt infinity!
This question has been answered many times before.
http://community.bt.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3AOthe...
There is also some advice on this link.
Wireless problems and things you can try, to resolve them
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
Expert
0
[ Edited ]
Best thing to do is get a Wii Lan Adapter for the Wii and connect through ethernet. Works for me everytrime now but no good on the new Wii U, the internet wirelss is terrible on the Wii U, they need some sort of upgrade cause the wireless card is already enhanced to be used for the Wii U but so bad anyway, ethernet connection gives a worse connection and lower speeds. Go to your DMZ in Home Hub and select your Wii or Wii U to the DMZ it does help a little bit.
Please click on pink star to the left and say thanks if I have helped you at all!. :smileyhappy: Thank you. Home Hub Page- http://bthomehub.home/
BT Speed test- http://www.speedtest.btwholesale.com/
Speedtest:-http://diagnostics.bt.com/login/?workflow=Speed
Net Connect test- http://netalyzr.icsi.berkeley.edu/index.html
Newbie
0
I've looked through and tried some of them..... Why is it so hard to do this with Infinity? Absolute joke from BT!
0
Its not an Infinity issue, just a home hub 3 issue. The home hub 3 is also used on ADSL connections.
If you have tried all of the options including changing the encryption type to wpa only, then all you can do is what has been suggested, get a wii Ethernet adapter, and connect using an Ethenet cable.
