Do you mean
Newbie
0
Port Forward Question _ BT HomeHub 3
Hello all,
Ive been trying to set up port forwarding on my bt router but to no avail so far.
On the port forwarding tab in the router settings when I click Add to assign a device nothing happens??
Ive tried on my iphone and laptop and the "add" button turns grey but nothing happens?
Can anyone help?
0
Re: Port Forward Question _ BT HomeHub 3
[ Edited ]
so your selecting the "game or application" then selecting the "device" and the "ADD" button stays grey?
or can you select add but after selection and the page refreshing the new device doesnt show up?
under "supported applications" you can manually set up a device vis "new game or application" as a last resort
Newbie
0
i have just managed to do port forward
1 use a pin and reset homehub3
2 select game or application
3 when selectiing device use user defined enter 80 80 enter ip address of device, add then apply
