Do you mean
Newbie
0
Problem connecting Samsung Smart TV to internet
I'm having problems setting up the wireless connection. I'm using a Netgear DGN1000 router which works fine with my pc and laptop. The TV recognises the router and connects to it but it then says it can't connect to the internet and says check DNS settings. I saw on another post some suggested static DNS settings which I manually entered but then the TV wouldn't recognise the router.
Anyone any ideas?
0
Re: Problem connecting Samsung Smart TV to internet
Possibly static IP addresses may help, but I can only suggest setting for the home hub, which are unlikely to work on the Netgear, as its on a different subnet.
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
