Do you mean
0
Whatsapp via wi-fi not sending messages
ok so I've had this issue for a while thinking it was my iphone 4 just being temperamental,
But I have recently upgraded to the iphone 5 and this trouble has persisted this means the issue must be with the wifi as I have checked both iphones just using 3g and I have no issue sending messages
I have tried the iphone 5 with static ip and dhcp addresses and still no luck this issue is intermittent an the messages will send after an app restart, could it be a port problem? Any other ideas?
vg0
0
Re: Whatsapp via wi-fi not sending messages
Hi, i think im having the same problem.
Things i have tried, iphone4, iphone4s, iphone 5, reinstalled whatsapp.
all work fine over 3g connections.
when connected to bt infinity over wifi they sometimes fail to recieve/send messages. even though it says connected in whatsapp.
I have tried different wireless routers, and different routers in place of the bt home hub. all have the same issue, the only common thing i can see is that it is using a BT connection, good to see im not the only one.
Its like after a while it seems to lose connection even when it thinks its connected, force closing the app and opening sometimes works, its just strange that i only have this problem when using bt wifi, over any other wifi connections and 3g is perfectly fine
