Do you mean
Newbie
0
bt infinity extension/amplifier ?
I have bt infinity installed,no problems and good downloads speeds.But i lose my signal at one end of my house approx 25 meters from hub(also the walls in my house are very thick).Is there a solution for my loss of signal ?Can anyone recommend something to purchase ?
0
Re: bt infinity extension/amplifier ?
These two links should help you.
Wireless connection problems
Network connection problems and possible solutions
There are some useful help pages here, for BT Broadband customers only, on my personal website.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
0
Cable clips and a length Cat5e or Cat6 eternet cable, you can have a single length run of upto 100m, maplin have ethernet patch cables upto 50m, you can then put your HH3 or HH4 more central in the house, connect the red port to the openreach modem with this longer cable. The Openreach modem should stay where it is close to the Master socket.
It of course depends on how tidy you need your cabling. :smileywink:
0
A good reply but the Original Poster has not retuned since his post in November 2012
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
