Do you mean
0
Accepted Solution
homehub 3 and cctv
im wanting to connect my cctv to my homehub 3 so i can watch it on my iphone while im away i have gone through all the port forwarding stuff but i can see it when im on my home network but not when im out and about any ideas how i do this
any help will be greatly appreciated
dave
0
Re: homehub 3 and cctv
They is a current known issue with port forwarding on the HH3, it is being looked at; hopefully an update will be released shortly. If you really need this feature you could always use another router.
There may be a work around specific to your problem, hopefully some tech may step in.
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. :smileyhappy: ***
0
0
thanks for your reply i hope either the update is soon or a tech guys steps in to answer too
0
I get my HH3 and Infinity installed on 6th May and am also hoping that my DVR CCTV will run as it does with my Belkin router and regular BBand at the moment. I'll let you know how I get on and update here if I get it running or not. Hope it all works as this is the main reason for upgrading to Infinity.
0
0
I set up the port forwarding on the hh3 without any issues
0
Couldn't wait for Infinity setup tomorrow (and I received the HH3 already yesterday) so - Just tried my CCTV and port forwarding. Not running here also. Setup DynDns and that's updating alright but like others cannot get access. Even setup CCTV using DMZ and still no access. Also selected IP address like others have suggested in other posts. Very disapointed since video etc is the reason I'm moving to INFINITY at 40 odd quid a month. Looks like I've got to buy a new router - AGAIN. (Just bought a Belkin PlayMax HD in February which will not not usable with Infinity). I'll contact BT to see if they have solution for port forwarding as this is just not good enough.
0
hi if you set up port forwarding without anu issues please do sday how you did it as im not the only one that are having issues and the whole point of this post was to get help to do it,
many thanks in advance
dave
0
Ditto to Dave above..
I've tried everything yesterday and this morning with no success.
I have my DynDns account updating alright - I downloaded a port checker from DynDns and it says the port is open. So not being a tech'y and only reading what others say here - it's not forwarding to my CCTV.
Disabling / Enabling Firewall, Turning on/off UpNp, settting my DVR as DMZ. Adding the devide as its IP address rather than assigned name etc - Turning on/off the router - No success - just about to throw the router in the bin.
I e-mailed BT customer support and they called me yesterday to say that they can only assist with connection problems - no help with any hardware replated issues. So I'm stuck and waiting on anyone here who can offer any solution.
I'll give it a few weeks then if there's no solution then I go buy a decent router. Conclusion to me so far is that the Home Hub 3 is a piece of trash. I was expecting much more but all it is capable of is the most basic of operations.
And so BT give us super fast Infinity (which I have now at a cost) - but what use is it if I can't get to my network from outside!! At least I update my facebook page in super fast time.... lol
