Do you mean
17070 options
On another post a uggestion to use 17070 for quiet test was helpful.  I had no previous knowledge of this facility.  Is there anywhere to find out what the other options actually do ? I thought cleandown sounds helpful but what happens ?  Thanks for information.
Re: 17070 options
1: Ringback test, this is why you need to clear down. (replace phone)
All other options are for Openreach use only.
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Recognised Expert
Re: 17070 options
Option 1 is Ringback
Option 2 is Quiet line
Option 3 is the openreach engineers test system
