Do you mean
BT Freelance XB2500 triple phone set
 New to this forum . I'm having problems with this phone set and the user manual does not provide the help info .  symptoms - the phones receive incoming calls and the answer phone operates automatically . If we pick up the phone the handset it just displays the handset ref number - they do not operate- we can't dial / no dialing tone . If we pick up the phone for a dailling tone the display on the hand set says 'Not Possible ' and an audible engaged type tone operates . We know the line works as it recieves messages on the answer phone . The hand sets are not locked . I tried ringing the help line but after 15 minutes still no pick up . can anybody on the forum help ?? Thanks in advance bruce
Recognised Expert
Re: BT Freelance XB2500 triple phone set
[ Edited ]
Are the handseta associated with the base correctly  see page 26
Most come ready when new
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Hi thanks - checked the handset matching to base station and it failed - went into searching mode with aerial icon flashing .I moved the base away from other electrical bits and went through reset procedure and they now work - fingers crossed they keep going thanks again bruce
