Do you mean
BT Freestyle 750 - answer machine messages have wrong spoken date (day of week)
Hi All,
I have set my handsets to the current day and time but the answer machine quotes the wrong day when speaking the message received details - it always 2 days out ie. later than it should be - when it should quote Wednesday as the day of the message Monday gets spoken out. Any idea why?
How can I correct this?
Thanks. George
Community Manager
Re: BT Freestyle 750 - answer machine messages have wrong spoken date (day of week)
Hi georgeturner,
Are you given the option to change the year? I had a look at the userguide and it mentions changing the "date" without really specifying if you can select the correct year - another customer on the forum had a similar problem and by updating the year it fixed the problem for him.
Let me know how you get on.
Stephanie
Community ManagerStephanie
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thanks
Newbie
Hi,
We had the same problem and found the year was set at 2008 instead of 2010.
Regards,
jaycee
Newbie
Hello there, can you please please please tell me how you changed the year as it's driving me absolutely crazy!!
If you are have caller display on your line, then date and time are set automatically on first incoming call.
Forumhelp (personal website) is back, with lots of useful info for BT home broadband customers..
Newbie
Hello there and thank you for your quick response.  The date and time are great and work perfectly fine but the answering machine always tells you the wrong day.  I therefore looked online and somehow the year is set wrong on the phone and so the date set by caller display is conflicting with the year set on the phone and giving me the wrong day all the time, saying it's Wednesday etc. when it's Sunday.  Nowhere can I see (looked in instructions and online) a method of changing the year but clearly from the forums people have done this, I just want to know how!
Newbie
Any resolution on this issue I have the same bother.  I was previously using BT 1571 for messages but now using answer message and unable to change year so as to get correct day of message!
regards
Newbie
Hello there
are u able to advise how to change the year with this phone?
regards
Newbie
Hello there,  if you go to the no1 handset and press menu you can scroll through the options with the up and down arrows on the side of the phone.  Scroll down to settings and press the menu or tick button on the right.  Then scroll down and go into the time and date settings and again press the menu or tick button on the right.  Then scroll down to the enter date section and you should get the year option.  Make sure it's the current year and it should then work our the correct day.  Hope it works for you, if not let me know.  Regards, Annette
Newbie
Thanks for that Annettedinah, at last the phone works as it says on the box-2 years later!
Ray
