Do you mean
BT Studio 1500 no dial tone
We recently moved the phone for a month during building work and now I can 't get it working again.
The landline is fine, the base handset is fully charged. The rechargeable batteries are charged.
We can even make internal calls between handsets 1, 2 and 3. However, no dial tone at all.
I have tested the line with another corded phone and it is fine.
How can I get the base phone to pick up the line again? I want to go back to how it used to be!
I don't want to have to replace this kit as it is obviously in working order? Anyone have any tips for me? Thanks in advance...
Recognised Expert
Re: BT Studio 1500 no dial tone
Maybe its the cable connecting the phone to the landline socket thats faulty see if the one on the corded phone fits
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
HI, thanks for the suggestion, but I tried that. I thought perhaps there was a kink in the cable so I tested it with a working cable. The problem still exists. Do you think it the number 1 handset has just de-registered from the base phone?
Can anyone from BT please answer? The 'helpline' number is obselete with no forwarding number. I think this is why BT has a forum isn't it?
is it true that they just stop
Recognised Expert
Could happen just try to rereg it
I don't know if my problem is related
My twin phone extension works ok
The base unit phone has suddenly got a loud swishing noise instead of a dialling tone
Can anyone help, please
