Do you mean
Newbie
Accepted Solution
BT Synergy 4500 Handsets wont unlock
Hi,hope someone can help.I have a quad set and two have become locked and wont unlock.I have checked the manual and just cant seem to sort the things out
  Any help would be much appreciated.
BRIAN...
Newbie
Re: BT Synergy 4500 Handsets wont unlock
OK,,,,,Im not that techy but,its quite by luck we sorted the answer.
Answer
  First press the centre top button nearest the screen on the handset[one above the menu arrow with a black line in it].Then press *[star]twice.
  Jobs a goodn.
BRIAN...
