Do you mean
Expert
Accepted Solution
BT Synergy 5500 Rechargeable batteries
Bought the above and it came with two rechargeable AAA batteries for the handset. These NiMH batteries are rated at 550mAH and so does anyone know whether any other capacity batteries can be used i.e. 750 or 1000mAH? Is the charging circuit only matched to the supplied battery capacity?
Distinguished Guru
Re: BT Synergy 5500 Rechargeable batteries
Hi HHGTTG and welcome
Yes you can use 750 or 1000mAH batteries
mAH = milli amp hour
So in your case, a fully charged 500mAH battery would last for 1 hour if the device being used was using 500 milli amps.
If the same device was powered by 1000mAH batteries, it would last twice as long between charges.
The higher the rating (mAH), the longer it will last.
(hope that makes sense)
-+-No longer a forum member-+-
Expert
Thanks. I have had conflicting info. regarding my question telling me that the charging circuits would not recognise or work with higher capacity batteries, although with my other electronic devices involving rechargeables I have always bought the latest, highest capacity batteries for them compared with the 'old' types originally supplied.
