Do you mean
0
BT Xenon 1500 - Phonebook only on one phone
Hello,
I have just bought a Xenon 1500 Triple Pack of phones. The issue i'm having is that I have entered the phone numbers of a few peopile onto one of the handsets, Handset Number 2 I think. I expected the entered numbers to then be transmitted to all the phones in the set.
Is this the case?
Do I need to use Handest 1 or should it make no difference?
Cheers
Carl
0
Re: BT Xenon 1500 - Phonebook only on one phone
You have to enter the numbers into each handset individually, the are stored on the handset, not the base.
There is no directory copy facility on these phones accoring to the manual.
