Do you mean
Newbie
Accepted Solution
Beeping message alert on BT6500, can i stop it ?
Can anybody tell me how to stop the beeping om my Bt 6500 its very annoying, cheers.
Moderator
Re: Beeping message alert on BT6500, can i stop it ?
Hi smashngrab,
Welcome and thanks for posting. You might find the answer here. Let us know if that helps.
Cheers
Community ModeratorDavidM
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Newbie
Yes you can - and here is how to do it.
1. On the handset select Menu, Answer Phone is displayed, press Select
2. Press CALLS until Settings is displayed, press Select.
3. Press to highlight Ans. & record and press Select.
4. Press to display Message alert and then press
or to select  On or Off and select Save.
Saved will be displayed and the annoying machine has now been de-beeped lol for good.
Newbie
Brilliant! Thanks. It works the same on BT8500
Thanks very much. Also works for BT2500 (Usefully, the number of rings before auto-answer is also set using this menu option).
