Do you mean
Newbie
Broken Telephone Manhole Cover
Near to the Kerswell Close bus stop on the south side of St Ann's Road, London 15, the surround of the telephone manhole cover is badly broken.
Photo attached.
Regards
annie45
Re: Broken Telephone Manhole Cover
This is a public forum, and is not suitable for reporting plant faults
You need to report it to Openreach on this number 0800 0232023.
Forumhelp is back online. Some links may be out-of-date, but I will update them when I get time.
Hi annieb45 you can report it to Openreach on this number 0800 0232023 if you spot any of the following so we can attend to it quickly:
Damaged underground cables (typically caused by mechanical diggers in built-up areas)
Loose cables or cables dangling from telephone poles
Damaged green cabinets and/or open doors on them
Damaged telephone poles (e.g. poles leaning at awkward angles, or poles that have been completely smashed to the ground)
Loose, cracked or missing manhole covers
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Recognised Expert
Post Office Telegraphs! That manhole cover is probably older that time itself, just goes to prove they don't build em like they used to if its lasted this long.
