Do you mean
0
Accepted Solution
Caller display
I came back to BT as from last Friday, my BB and phone line was activated in the afternoon of the same day. But my caller display was not working, even though I had asked for this on my original order. I rang BT and was put through to India where the gentleman on the line asked if I wanted an engineer to call. When I said that I thought that this was unnecessary he said he would place a new order and the service would be activated in about 24 hours. It is now 48 hours and still no caller display.  Has anyone got any thoughts on this subject.
Distinguished Guru
Re: Caller display
Try dialling *#234# you will get an automated message saying if numbers will be displayed
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Re: Caller display
Try *234# to activate the service and make sure you have the phone plugged directly into the line. Microfilters etc can affect the pulse.
Distinguished Guru
0
Re: Caller display
You can only get caller display by calling the service dept or by accessing your BT online account.
0
Re: Caller display
Hi Devon Dave, Thanks for the reply it worked fine caller display is now up and running.
0
Re: Caller display
Hi caerdydd, Thanks for the quick response and for the info. Its working fine now after I called BT this morning.
