Do you mean
Calling Features PIN number
Hello
My PIN is not being recognised  - I've tried 1234 but it doesn't like it.  I must have changed it at some time in the past.  How does one go about resetting this please?  I have searched the BT web pages for too long!
Thanks.
Distinguished Guru
Re: Calling Features PIN number
The pin number for what calling feature?
A Pin number is only required for.
1. Call Barring
2. Choose to Refuse
3. Call Minder
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Hello
It's for Choose to Refuse.
Distinguished Guru
yes, the default is 1234. so as you say you may well have changed it.
you will need to contact 150 or 0800 800 150 to get it changed
OK thanks for that.  Have you any advice on which options to go through on the phone?  I tried yesterday but enquiries in respect of calling features go to an automated service.
Thanks Ray - but I was actually enquiring about the option numbers to select after dialling 150 in order to speak to someone about resetting a PIN.  I think I'll just have to act dumb and go through to sales or something.
