Do you mean
Newbie
0
Can't receive incoming calls
When incoming calls arrive, my BT Graphite 1500 hub phone just keeps on ringing, even when I lift it off the cradle and press the relevent button.  The other phones will receive the call.  The hub phone seems otherwise fine (ie I can phone out).  So why won't it stop ringing and let me answer incoming calls?  SHFH
Distinguished Guru
0
Re: Can't receive incoming calls
It does sound as tho the phone itself has gone faulty, do you have a spare corded phone you can try in place of the graphite?
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
