Do you mean
0
Forgotten BT email address AND password.
Hi we got given a email and a  password  but we have gone and lost it how can i get it back as we need it to access our account on line.......
Distinguished Guru
0
Re: Forgotten BT email address AND password.
I'd of thought that if you go to http://www.bt.com/ and click on the forgotten (next to username), it should direct you to a security page whereby you'll be asked the security questions you used whn the account was activated.
Not sure though but worth a go IMO.
-+-No longer a forum member-+-
0
[ Edited ]
As would normally be expected you do mean just the password and not both?
If it is both and you have sent or received emails previousky, which have been deleted some email clients do not actually erase them and can be recovered with a program like Recuva (freeware). That would reveal the user name as a first step.
0
Go to this page:
http://bt.custhelp.com/app/answers/detail/a_id/8517/c/345,5388,5393
Among other things, you'll find a phone number: 0800 111 4567
Select technical queries (or somesuch) from the options and a guy in India will sort you out. - You'll need to answer some security questions.
0
As DS posted just go to my BT and you can recover both password and username from there
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
