Do you mean
Accepted Solution
How can I stop anonymous withheld numbers ?
Dear BT Community,
I would like to stop all withheld anonymous numbers on my home phone.
How can I do this please with the caller getting the message that they have to dial again without withholding the number ?
Many thanks.
Distinguished Guru
Re: How can I stop anonymous withheld numbers ?
Thank You DS
Would I be correct is saying all I have to do is enter to code to set it up and the monthly charge goes on the phone bill ?
Thank you again.
Distinguished Guru
Yes, that does appear to be the correct way.
However, I always ring BT to confirm that things are set up correctly on my account - belt and braces
Should you have any issues, please let us know.
-+-No longer a forum member-+-
Thank you DS for your help, it is much appreciated.
Its getting very annoying when, despite being on the telephone preference list, I keep getting silent calls and although they are supposed to leave a number if you try and call back, its withheld.  Probably an overseas call trying to sell something !
At least if I have the restriction on the line, it will help.
Many thanks again.
Ann
Guru
Many thanks again.
Ann
Hi Ann, Unfortunately it will not stop any International calls from abroad, and a lot of the nuisance calls originate from abroad.
As far as I am aware there is only 1 thing that stops virtually everything and it is a 3rd party unit. It costs money, but then so do some of the services like ACR from the likes of BT
If you do a google search for Truecall you will be able to find out about it.
I am a user of truecall and as they offer some services that BT offer , feel I should not post any more info about it in the forum .
If you need more information you can PM me direct.
toekneem
(EASBF)
Distinguished Guru
[ Edited ]
The good thing is, they will now get a recorded message saying they need to unblock their number - should put most offSmiley Happy
edit. I doubt it is overseas.
These are driving me insane, but no way am i paying £5.40 a month for the privialge to block them!!
that is your only choice
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
