Do you mean
0
Accepted Solution
How do I find out my own phone number?
0
Re: How do I find out my own phone number?
Trial dialling a phone or mobile with caller id. Prefix the number with 1470 so it will show. This should give you the number.
0
Thank you
Distinguished Guru
Or even easier, just dial 17070.
Distinguished Guru
or 1470 17070 if your number is withheld
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
0
Thank you
0
Thank you
0
thank you very much
0
Thank you
