Do you mean
0
How do I report a fault if my phone is not working?
How do I report a fault if my land line phone is not working? The BT website seems to assume that at the very least the broadband line is working but this is often not the case. Please could you make it crystal clear what phone number to call to report a fault? (e.g. if calling from a friend's phone or a mobile).
0
Re: How do I report a fault if my phone is not working?
[ Edited ]
Cal 0800 800 151 from another phone, or From a mobile: 0330 123 4151
But first do these tests here  http://bt.custhelp.com/app/answers/detail/a_id/9812/c/345,353
You can report the fault online at https://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=2&s_cid=con_FURL_faults
Polite request to forum members who may have the same or similar problem. Please could you create your own thread on this forum, and avoid hijacking this thread.Otherwise its likely your problem will not be resolved, as it may have a different cause, and it also makes it difficult for forum members, who are trying to help the person on this thread. See How to post a new question
Newbie
0
"Sorry, you can only access this site from a BT broadband connection"
you muppetz BT.
if the sodding thing was working i wouldn't b worrying would i.
so if the poxy thing is broken how could i be looking at your web**bleep**e?
[ Edited ]
The link you tried was to Keith's personal web site and is part of his signature there is no need to be so rude on a customer to customer self help forum when a customer tries to help you
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
