Do you mean
Newbie
0
How much does bt charge for 0870 numbers
I have been on the phone for over 30 mins and still on hold, just wondering how much this will cost me
Recognised Expert
0
Re: How much does bt charge for 0870 numbers
[ Edited ]
Hi There and welcome, if your calls are with BT and you are NOT on the anytime plan, 7.60p per minute. daytime rate.
If you are calling BT why didn't you use the freephone number.
EDIT   I  don't think there is another number for BT
Guru
0
If you the BT anytime call package calls to 0845 and 0870 are included and therefore de facto free
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Newbie
0
What? £7.60 a minute? I was phoning EA support and it started with that number. Im not sure what plan I am on.
Recognised Expert
0
[ Edited ]
Please note that I said 7.60p a minute not  £7.60 a minute!!!!!!!
There are 3 plans for phones
Unlimited anytime. 0870...0845 numbers included anytime
Evenings and weekends (above included at these times)
Weekends (above included)
Patty-L
