Do you mean
Newbie
0
Accepted Solution
How to replace a master socket?
Hi,
as you can see from the photos, my master socket is very old.
I would like to replace this socket with a new one so I can plug in a broadband router. Currently, the router is a long way from the master and I'm sure the distance is affecting the speed of the broadband.
My question is this: if I buy a NTE5 and an ADSL splitter, is installing them something that I can do? I'm not great at DIY!!
0
Re: How to replace a master socket?
[ Edited ]
That is just a normal terminal box.
How does your phone plug in at the moment?
A master socket will look like one of the first two here.
One of these
Or one of these
Or if you are lucky
One of these
Newbie
0
There is a cable that runs from the terminal box to a box under the stairs that looks a bit like this:
0
That is your master socket. Is your home hub plugged in there, or in an extension that runs from that master socket?
Newbie
0
The router is plugged into an extension cable that runs from the socket.
0
Is it possible to plug it into that socket?
What are your ADSL stats
at the moment.
Newbie
0
Yes, it should be possible. Is it worth upgrading this master socket?
Newbie
0
Braodband speed is about 1.1MB at the moment. Neighbours are getting 1.5 - 1.7MB
Newbie
0
[ Edited ]
My broadband speed is about 1.1MB.
Neighbours get 1.5 - 1.7MB
We are quite a long way from the exchange so I would not expect to get more than 1.5MB or so.
0
[ Edited ]
If you can post your connection speed now, then I will suggest a method to test whether upgrading the socket would be worth it.
I need the full ADSL stats from the BT Home hub, as mentioned in my earlier post.
Then I can check the attenuation and noise margin, and give you an answer.
