Do you mean
Newbie
Maximum number of phones to a domestic landline
Hello there
Is there a maximum number of phones that can be connected to a domestic land line?
I would like to connect 7 handsets including a fax machine to 1 domestic land line.
Thanks i advance
Re: Maximum number of phones to a domestic landline
If you mean the number of handsets then no, you can connect as many as you need/want.
Hope that helps.
Recognised Expert
[ Edited ]
Not true each phone has what is known as a ringer equivalance number
and I think a number of 4 rem  is still the max
Each item will have its number printed on it you just add them up
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Newbie
How can you increase the number beyond 4?
Use a cordless base, with a number of handsets - AFAIAA, only the base counts toward your total.
Recognised Expert
True and the base will have its loading number on it
You can get a REN booster so that you can have more than 4 REN loading on your line.
Peter
