Do you mean
Accepted Solution
Missed calls
My hub phone is set to ring on BT broadband talk only and my phone socket is set to ring on BT broadband talk and land line
so why is it that when I receive a call on my land line which rings and answer it it is shown as a missed call on the hub phone which does not ring.
As I answer my land line and have not missed ther call why does this message appear on my hub phone.
Distinguished Guru
Re: Missed calls
Hi and welcome to the forum.
I am afraid this is one of the quirky problems with the hub phone and has been like it since it's inception.
It is the phone that sees it as a missed call not the phone line itself, I believe this has also occured on certain types of multipack cordless phones, if you answer the call on handset one, the others can show as a missed call.
Sorry, you will just have to live with it.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
