Do you mean
Newbie
New phone, works but does not ring.
I have purchased a new phone, it is working fine but on one extension it works but does not ring out when a call comes through. Any ideas what this could be, it can be used for calls etc. but just doesn't ring?
A lose wire in the extension? incompatible extension socket to phone?
Re: New phone, works but does not ring.
is it a particular extension socket that has a problem - does it work when using the master socket? or test socket?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
If it works in your master socket, then there must be a fault somewhere in your extension wiring, broken wire perhaps?
There is some help here http://www.telephonesuk.co.uk/wiring_info.htm
Forumhelp is back online. Lots of helpful information on BT products.
Some links may be out-of-date, but I will update them when I get time.
Newbie
Thanks I will try and figure out the wiring.
Works fine in main socket, just doesn't ring on the extension.
check the wires are not loose on the back of the bottom half of the main socket and in the extension socket
