Do you mean
El
No dial tone
My mum has phoned me on her mobile to say she has no dial tone on her home phone. She lives 30 miles away so can't just jump in car and fix it. Have checked line for fault online and says there isn't one.
Have got her to check her phone is charged up and she has tried both her home phones in the connection box but still no joy.
She is an elderly pensioner and really need her phone but not wanting to pay the costs of getting an engineer. Is there anything else i can suggest to her.
She has bt affinity as well as broadband and they all seem fine.
Re: No dial tone
I have moved this post to the phones board as it is more appropriate
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Re: No dial tone
[ Edited ]
hi I would suggest you phone BT faults on 151 and report no dial tone there should be no charge if the fault is not on any of the phones in the house infinity operates differently and is not affected by a phone
fault
Try a Search
Recognised Expert
Re: No dial tone
Has she tried an known working phone into the NTE5 test socket, you said she has Infinity, if she does she will have an NTE5.
If it doesn't work into there then it will be a fault on the network and you will need an engineer out.
El
Re: No dial tone
HELP!!
Have tried everything suggested and the box is not the same as the one shown but we have taken it off the wall to check.
Phoned the 151 automated thing on my mobile so thats gonna cost and basically it just checked line to tell us again there was no problem with line!!!!
What can we do without getting charged
Re: No dial tone
If you have tried two phones, then its likely to be an external fault.
You can report it here https://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=2&s_cid=con_FURL_faults
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Recognised Expert
Re: No dial tone
To be honest I wouldn't pay to much attention to the automated line test system as it can only pick up hard faults like a disconnection in the network.
Ring BT faults and ask for an engineer visit from Openreach to come and sort the problem because all the goodwill of people on this forum ain't gonna fix it.
bfg
Re: No dial tone
Hi El,
As Plainview suggests, it might be time to speak to someone at the BT faults helpdesks, try ringing 0330 1234 151 from your mobile (its a low cost version of the 0800800151 number for mobiles) or 151 from a BT line, 0800 800 151 from another service providers line, as its free.
BT will charge for 3 reasons:
1 - Damage has occured to the BT network in the property (cut cables, smashed sockets etc).
2 - Your (or your moms) equipment causing the fault (old phones, double adaptors etc)
3 - Nothing wrong with the line.
If you have unplugged ALL equipment from the line (including any alarm system working on the BT line, sky box, etc) and tried, either, a phone that definatly works or two seperate phones (two handsets from the same bases tation are technically one phone) you should be ok.
the socket shown allopws you to remove the extensions (and wiring) from the line as they are connected through the face plate part, so if you did have this socket you can elimibnate any internal wiring faults, but if you dont have that type, you need to make sure you try yopur working phone on its own in to teh main socket (try them all if your not sure which is the main one, or if only one sockets its easy;-) )
You can also log the fault through BT.com.
hope you get it sorted.
Distinguished Guru
Re: No dial tone
Hi
Are you certain that you do not have the line box as shown by John? it is just that if you have BT Infinity you should have one somewhere.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Recognised Expert
Re: No dial tone
Devon_dave is right, if your old lady has BT Infinity she will have an NTE5a with a Service Specific Back Plate, it will look like this;
If she doesn't have one of those then she won't have BT Infinity or any FTTC product installed by Openreach.
