Do you mean
Accepted Solution
Noise margins or line retraining
Hi all
Is it possible to have my line noise reduce from 9db back to 6 or even 3 as it used to be failing that could my line be retrained please
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Moderator
Re: Noise margins or line retraining
Hi John46,
Thanks for posting. I can check your line and see what's going on. Drop me an email with your account details and a link to this thread for reference to forum.moderation.team@bt.com.
Ta
David
Community ModeratorDavidM
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Thanks Dave
Details mailed to you
Try a Search
