Do you mean
0
Old master socket replacement
Hello there
We've been having problems with our phone line and broadband lately, phone all crackly and broadband cutting off/ huge speed drop.
The socket we've got is an old lJU5/1A dual master.
(pics - http://img3.imageshack.us/i/photo0100db.jpg/ , http://img255.imageshack.us/i/photo0101s.jpg/ , http://img529.imageshack.us/i/photo0102r.jpg/)
Can these be replaced by us , or is an engineer needed to do it. If so will we be charged for it.
Recognised Expert
Re: Old master socket replacement
[ Edited ]
From a legal point of view only BT can do the change however many people do it themselves it is simple enough
read here may help
http://www.kitz.co.uk/adsl/socket.htm
I'm sure BT would charge to replace it
the crackly phone is the reason your broadband is poor
Have you tried a quite line test
dial 17070 option 2 and listen - should hear nothing
best done with old type analogue phone digital will do but may have slight hiss
do not use home hub phone
and read here http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
May be an idea to post about broadband in the BB forum Smiley Very Happy
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
0
should we decide to replace it ourself what socket would you suggest we put on.
As you can see from the pics the wiring is not like anything shown in any of the update guides i've seen.
Recognised Expert
0
[ Edited ]
The type you have fitted seems to be the filtered filtered NTE5 where the adsl is only available on the master socket not on any extensions and it should not require a separate adsl filter  ( not so as pointed out by DS )
If you are happy to keep the router plugged in to the master adsl socket fit filtered NTE5 type  as it is the best as far as filtering goes
If you wish to site router on extensions use the NTE5 box last item in the Kitz page
Distinguished Guru
[ Edited ]
The socket is not an NTE5 but an old style (pre 1981) twin master idc fixed plate socket (known as a LJU - line jack unit).
An ADSL filter will be needed.
The internals on the images are a capacitor, resistor and a surge arrestor.
-+-No longer a forum member-+-
Recognised Expert
0
New one to me thanks for correction
Recognised Expert
0
For future reference. Smiley Indifferent near the bottom of the list.
BT sockets and Line Jack Units
http://www.kitz.co.uk/adsl/images/phone/LJU5-1A.jpg
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
Newbie
0
hi im having the same problem withe old socket  and have been told by  BT that it would cost £99 for a change
[ Edited ]
I've never figured out how a minority of people got stuck with antique sockets.  However:
It is not legal to replace the Master Socket yourself.  I know a few people who got a free replacement on the strength of the broadband problems they were having.  I guess Openreach engineers typically think "I can fix the broadband problem quickly by replacing the old master socket with a new one with a built-in broadband filter.  The Master Socket belongs to BT, ergo the replacement is free".  But if you just ask for a Master Socket replacement it will cost you £99.
Distinguished Guru
I'd guess it's a hangover from the 70s/80s when there were plenty of DIY jobs by people replacing their wired-in phones with something they could plug in which trilled instead of rang. It's not illegal to mess with the master socket; it is a breach of the T&Cs though, and will cost if something goes wrong.
You can click the white star next to this message if you think it was helpful.
