Do you mean
Newbie
0
Accepted Solution
Phone line removal
Hi all,
Is it possible to have a BT phone line (from pole to house) removed? We recently moved to a new house and plan to do some building works. Afterwards we will be using Virgin Media for phone/internet/TV. If so will there be an associated cost?
Many thanks, Adam
0
Re: Phone line removal
This link may help you http://www.openreach.co.uk/orpg/home/submitFeedback.do?contactReason=remove_relocate_external_networ...
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
0
John, thanks for the link, much appreciated. I have tried to fill in the form but it just gets stuck in a loop (next, confirm, next, confirm, next...). Will try on another laptop to see if I can submit.
Cheers, Adam
