Do you mean
Unrecognised phone number on my bill
Hi.  I'm new to the forums and apologise if there is already a thread about this problem.
I use the phone very little, but have just checked my recent quarter's usage and find two very short calls at 0105 and 0107 (yes - in the small hours!) in the morning of Christmas Day.  These are both to an 0871 number.  Now I know for a fact that I was not at home then as I was at Midnight Service at church.  Is there any way of finding out how these calls happened?
It's no big deal moneywise - just a few pence each - but I would like very much to make sure it doesn't happen again.
Re: Unrecognised phone number on my bill
Have you tried entering the number into a Google search to see if it gives a clue who it might be?
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Distinguished Guru
Do you have any other devices connected to your phone line? Like a burglar alarm, a care alarm. There are even devices that can connect now that will order your heating oil when you run low, so it could be something like that. As Keith suggested if you google the number dialled it may give you a clue.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
I tried Googling the number but without success.  The only things I can think of are a burglar alarm (and it isn't anything to do with that) and Sky - but I would have thought that it would have come up on Google if it had been anything to do with Sky.  Very weird.  I guess it isn't really worth worrying too much about, but I'm just intrigued.
Distinguished Guru
The sky box does make a call out, normally in the early hours of the morning, but this should be an 0800 number.
If you post the numbers it's not too hard to find out if they are commercial phone numbers rosered.
Kind regards... Tom
BT Infinity2:
The number in question is 0871 2005086 (both calls were the same number) - if anyone recognises it, I'd love to know what it is.  Like I said earlier, I tried Google but couldn't find anything obvious.  (I'm no expert so perhaps I've missed something).
When I put the number 0871 2005086 into google I get told it is the number for tracking a UPS parcel?
I see what you mean, but I suspect that it's not a phone number in that context, rather a parcel number.
I can't find any reference to 0871 2005086 otherwise - all the phone number reporting sites don't have any complaints about this particular one.  I'm just so intrigued how two calls of only a few seconds each could possibly be showing on my call usage details at 1.00 in the morning of Christmas Day when I was safely playing the organ at church for the midnight service!!
May sound silly have you thought of phoning to see who the number belongs too
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
