Do you mean
bt vision
hi there,my phone line stopped working, got a mate round (bt engineer)the phone line at master socket and extension work only if i unplug my bt vision hub,I have full package, phone,broadband,bt vision.when i plug vision back in the tv works but  there is no dial tone .mate was scratching his head thinks it may be the hub or vision box as main line and extension wiring checks out fine also tried changing the filters but no use please help......
Re: bt vision
It could be a faulty home hub.
Do you get dial-tone on your phone if you connect things up as shown on this diagram?
Testing from "test" socket
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Re: bt vision
home hub is where extension is fitted,if i unplug bt vision both phone lines work fine when i reconnect the bt vision i have no dial tone just a voice recording saying please hang up and try again
Re: bt vision
When you say you unplug BT Vision, do you mean you unplug the BT Home hubs ADSL input lead?
BT Vision itself, has no phone connection.
Re: bt vision
sorry ,yeah when i just have phones plugged in phones work fine in master socket and ext, when i plug the adsl lead into the modem the broadband light goes steady,the bt vision works but the phone lines dont,no dial tone
Re: bt vision
It looks like a faulty BT Home hub, which version of the home hub do you have, and did you have any thunderstorms recently?
Re: bt vision
Do you have MicroFilters on each of the Phones?
"Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein
Re: bt vision
hi, no thunder storms to speak off,my mate changed the master socket to see if that would help,also yes i have filters in both sockets even tried new filters in case they were not working but still the same,i can have either both phones working  but no broadband or bt vision or have broadband and vision but no dial tone argggggggg
Re: bt vision
Which home hub version do you have?
This link will help.
Which version of the BT Home Hub do I have?
Re: bt vision
home hub 3,at the master i only have cordless phone plugged into microfilter, in sitting room at ext i have filter one lead goes to home hub the lead from the telephone side of the filter goes to the vision box, when both filters are plugged in i get broadband and vision but no dial tone at master , if i unplug the hub and vision from ext filter then i get dial tone at master and dial tone on phone side of filter at extension..
