Do you mean
Newbie
changing my BT landline number
Hi There,
Can anyone tell me the best way to change my BT landline telephone number?
Thanks in advance
Bill
Re: changing my BT landline number
[ Edited ]
Hello Bill
your have to be the account holder and ring 0800-800150 to change your LL number they may charge you for the new LL number ?
MARTIN
Distinguished Guru
Change of numbers are free
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
If you had LL more than 12 months,then it should be free.
Unless its changed ?
