Do you mean
id
Accepted Solution
flashing orange phone icon
Hi - wonder if anyone knows what's going on?  My bt hub shows flashing orange phone icon but the updating icon isn't lit up.  This has been happening for 3 days now.  The phone is working, so should I be worried?  Is there something I should be doing to remedy this?  Confusing!  Thanks for looking.Smiley Happy
Re: flashing orange phone icon
Have you ever used Broadband Talk?
Forumhelp is back online. Lots of helpful information on BT products.
Some links may be out-of-date, but I will update them when I get time.
id
No I have never used bt talk.  As far as I understand that would be chargeable, whereas I'm on free anytime calls.
id
No I have never used broadband talk.  As far as I understand that would be chargeable, whereas I'm on free anytime calls.
Its probaby been de-activated because you have not used it, that may be why the phone light is flashing.
I assume that its still flashing after  you re-boot the home hub?
id
Re boot the home hub?  Confession - I'm not technical!  Should I just turn it off and on again?  Thanks
Yes.
id
I turned the hub off, waited a few minutes and turned on.  Waited about 1/2 hr but the icon orange phone is still flashing it's little heart out.Smiley Frustrated
Is it is not affecting your Internet access, then just ignore it, or stick something over the light.
id
Fair enough mate,  thanks for your time.
