Do you mean
Re: no dial tone but works OK on the test socket
[ Edited ]
I would get a new faceplate. You may as well replace it with a filtered ADSL faceplate which will avoid the need for microfilters. See this website.
Improve your ADSL broadband connection speed
The section  -  Installing an adsl filtered NTE5 Faceplate
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Re: no dial tone but works OK on the test socket "Keith"
many thanks for the prompt reply, John, much appreciated.
What does Devon Dave and Keith think on this one? I ask becuase these two gentlemen have been involved from the start of my post and I would value there judgemnet as well.
I have just posted my suggestion....
ok gents.
Have ordered a replacement faceplate and a cheap plastic insertion tool.
Wil let you know how I get on.
Thanks again for the advice
please keep us posted
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Distinguished Guru
Sorry, been away on business. If there are no wires connected to the faceplate it does sound like the faceplate is indeed faulty.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Hi folks,
managed to get a new faceplate and a £1:50 plastic tool on Saturday.
took the old one off today and wired it back up  and....
all tickety-boo and working again!!!!!!!!!!!!!!
BB via the Homehub ok and all extensions working as well.
about £!2:00 all in inc p&P with the insert tool.
Only three wires to put back in, and as I made a note of them and where they went into 2,3 ad 5, ( and took a photo just in case:-)), it was pretty easy.
So much cheaper than calling BT out or getting another spark out.
Many, many thanks for all the advice and also your patience.
I hope many others follow this post through and have the same success as I have with your help.
Slan
