Message 1 of 2
Ask for engineer intervention
Good morning,
My question might be a bit stupid but I ordered BT Tv a few months back and didn't asked for an engineer intervention to full install it ( silly I know) and I wanted to know if I could ask for it now and if yes how?
Thank you for your help !
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Ask for engineer intervention
Hi @MaxyMaxy  boxes themselves are pretty much plug and play, provided that you have the hub / broadband connection nearby and can attach the supplied Ethernet cable, or are able to use Wi-Fi on the newer TV Box Pro.
If you want to drop me a private message by clicking on my profile and let me know what's needed, I'll see what I can do to get you sorted.
David
