Message 1 of 5
BT Broadband Renewal/TNT Sports
Hi,
My broadband package is due to renew on 1 August. We currently have TNT Sports as part of the package. When I go through the renewal options on the BT website it only brings up the broadband and calls option, nothing about TNT.
Is there a reason for this ? I'd like to keep TNT so what will happen after 1 August? Will it automatically renew ?
4 REPLIES 4
Message 2 of 5
Re: BT Broadband
Hi @Yarmy,
Welcome to the Community!
We want to make sure you're getting the very best plan for your needs, so I'd recommend giving our team a call, and they can double check that TNT Sports in included when your plan renews.
Rach
Message 3 of 5
Re: BT Broadband
OK, thanks, what is the best number to contact them on ?
Message 4 of 5
Re: BT Broadband
try retentions 08007831401   make sure you know what BT are offering new customers to help with your negotiations
Message 5 of 5
Re: BT Broadband
0800 783 1401 and choose the appropriate option.
