Message 1 of 3
BT Sport stream very dark on Roku Streaming Stick+
I’ve suddenly run into a problem when streaming through the BT Sport app on my Roku Streaming Stick+. It’s just started turning the screen really dark as soon as I join the live stream. All good while I’m in the menu but as soon as I go into a live stream it goes dark. It also sorts itself once I go into either Manager or Hype mode. I’ve restarted the Roku but doesn’t make any difference. Assuming it’s a bug that needs an update?
2 REPLIES 2
Message 2 of 3
Re: BT Sport stream very dark on Roku Streaming Stick+
My Roku's fine.
Presumably your TV has different picture settings for different inputs (live TV, HDMI, etc) I suspect your problem lays there.
Message 3 of 3
The match will be in HDR - this is often reported as being too dark when you're used to the SDR stream.
Use the Channels menu at the top to watch the regular channel instead of selecting the event from the home screen.
