Message 1 of 4
BT Sports HD Add-On
I pay BT for BT Sport and I watch it on Sky.
In order to view it in HD on Sky I need the BT HD Add-On.
If I place an order with BT for the Add-On it comes up as zero cost and says "FREE for the first 3 months".
What's the cost after 3 months?
3 REPLIES 3
Message 2 of 4
Re: BT Sports HD Add-On
£6.50 per month.
Message 3 of 4
Thanks.
Is that on a rolling one month contract?
If so, how do I turn it on and off? For example, I probably only need it whilst the Champions League is in progress.
How soon after the free first 3 months period can I turn it off?
Message 4 of 4
It would be a monthly rolling contract and you would switch it on and off via the MyBT app with your BT login. It should appear there as being free for 3 months and you should be able to remove it before being charged if you choose, but Champions League would have resumed by then.
