Message 1 of 3
EE box pro. strange problem
My set up is EE box pro to tv via hdmi and television is set up with aerial straight to tv. Therefore I watch tv as normal and just use the ee box for TNT sports stuff. The problem is that when I turn on the EE box and go to TNT channels, after a couple of minutes it turns the television off then back on again. I have tried factory reset but still the same.
Does anyone have any ideas how to correct this?
Thanks and regards
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: EE box pro. strange problem
Try turning off CEC control on the TV. You may have to Google what your TV manufacturer calls CEC.
Message 3 of 3
Thanks for the suggestion. Apparently it is called viera control on my Panasonic tv.
I have turned it off and things seem ok .
Thanks again.
