Message 1 of 3
Getting LP103 on Fire Stick 4K Max
Its saying i have too many streams active, but im the only one using the BT Sport app, on the one device; so how does it think i have too many active-streams? (Rebooted device and router, no deal)
2 REPLIES 2
Message 2 of 3
Re: Getting LP103 on Fire Stick 4K Max
It's never wrong. Leave it up to a maximum 6 minutes - if it still says it, then someone else is using your account. You'll need to change your password.
Unfortunately it can take up to 8 hours for their session to expire and release the streams.
Message 3 of 3
It worked after leaving and re-trying.
Password was changed just before Xmas, and only i have it, so if somehow it thought the Fire Stick was running more than 2, because i went initially to the Advanced player, but it wouldn't go 50fps, so ducked out and went to the channels and selected BT SPORT 1 and it worked. Only issue then, was my fat hands caught the remote, pressed the home button and after going back into the app, tried to restart BTS 1 did it say too many streams.
