Message 1 of 2
HD with Big Sport???.
Hello. Im thinking of joining BT. On Big Sport it doesnt mention if TNT & Sky Sports are in HD. Do I need to add the HD as an extra?.
Finally, is TV & Broadband easy to set up on my own, as I want to keep the cost down as much as possible?
Thank you.
1 REPLY 1
Message 2 of 2
Re: HD with Big Sport???.
If you buy from BT then HD is not included - you'll need the HD add-on.
If you buy from EE then HD is included.
Either option is very easy to set up - see this help guide:
https://ee.co.uk/help/tv-sport/getting-started/set-up-ee-tv-box-pro
(the broadband will be installed by an engineer)
